Blob filter explanation Thomas Wagner from Germany [51 posts] |
STeven,
Two questions:
* can you explain the meaning of the Object1, Object 2 tabs and give an example of how to use them?
* I know how to select the largest blob, is there a way to select the second largest blob?
Thomas
Some of the filter will allow for more than one object to be worked on. See the Overlaps, Furthest, Nearest and Join which use other object tabs. For example, you can use it to combine red and green objects. See attached.
To get the second largest, select the largest, invert the result and select the largest again. See attached.
