Execute AVM roborealm on two instances
Andrés from Spain  [3 posts]
Is there any way to run AVM roborealm on two instances of roborealm with two cams?
Yes, just check the Options button->Application tab->Allow Multiple Running Instances checkbox. That will allow you to run more than once instance of RoboRealm and will remember what the pipeline is for each when you restart.
Andrés from Spain  [3 posts] 12 year
Thanks for the reply. I can execute two instances of roborealm, but I cant execute AVM on both instances. I meant I need run AVM plugin on two instances of roborealm.
