Calculate angle
I am using the calculate angle module to calculate a 2 point line.
My start point is the center of the image and the end point is COG X and COG Y.
I am getting an angle 0f 112 degrees .It is making 0 left side of image and 90 degrees is bottom of image.
Is there a way to set 0 degrees at the top of the image and read the angle in a clockwise direction only, so right side is 90 bottom is 180 and left side is 270.
thanks for any help.
Yes, using one of the programming modules
SetVariable "angle", (270 + GetVariable("angle")) mod 360
or just where you use the angle
[(270+angle)%360]
See attached.
