AVM Navigator
Robert from Ireland  [6 posts]
I have been using the AVM Navigator module for use with my application and am just wondering is it possible for it to learn a new object using "Learn from Motion". Obviously it recognizes a new object from motion but can this new object be renamed, and identified again when it reenters the frame.
Any information or help with this would be greatly appreciated.
Regards,
Robert
EDV  [328 posts] 12 year
Unfortunately but you can't rename object that was trained from motion from index 0 to another. However you can remove object (that was previously trained) by single shot of NV_REMOVE_IDX to 0 (see here for more details: http://www.roborealm.com/forum/index.php?thread_id=5055# ). You should set variable NV_REMOVE_IDX to zero only one time (single shot) for clearing of the recognition data that was associated with index 0. If you would try to keep zero value in NV_REMOVE_IDX variable during long time then it could lead to clearing data without nonstop and in this case learning would not work.
