Testing an integer array for emptyness
CubaMadre from Germany  [12 posts]
I need to test in a robo file if there exists a Harris_Corner, how can I achieve it?
Does "if HARRIS_CORNERS[0] > -1 then" work?
TIA,
CubaMadre;
If you specify an array just by itself it will return the size of the array so
if HARRIS_CORNERS > 0 then
end if
should work since the size will be zero if no information is in that array.
