Roborealm+Raspberrypi+MJpg_video_streaming
Tomytha from United Kingdom  [2 posts]
I am trying to get a video feed into RoboRealm via Raspberry pi and Logitech camera which is configured to MJPG video streaming using IP address and Port number.
I am unsure as to what option to chose. The API server or Ser2Net.
I have tried to use the Ser2Net but installing it on the Raspberry Pi but having difficultes to set the port number, data bits parity etc. I am not able to get much online help on this either since it is too specific.
Your help would be much greatful !
Tomytha
Tomytha,
Not sure exactly why you tried ser2Net as that has more to do with command control rather than video streaming. I assume the Logitech is plugged in the Raspberry PI which then makes it very similar to what you do with the TP-Link router ... which is discussed in depth at
http://www.roborealm.com/forum/index.php?thread_id=5163
I'd take a look at that and instead use the HTTP Read module in RR along with running mjpg_streamer on the PI.
