Marker Problem with Crop Paul D from Canada [45 posts] |
I set a marker before cropping the image.
I process the cropped image and then want to revert to the source image.
the marker module used to allow this but now the reverted image is the same size as the cropped image.
Has there been a change to the handling of the canvas size that affected the marker module?
Thanks Steven
Paul,
This should have been corrected a while back ... can you check with your particular configuration? If not, we probably didn't replicate your situation correctly and could use you robofile as a test to see what may be happening.
