using weights
Robocop  [3 posts]
I´m using the blob filter module to give a blob the highest weight.
Now, the blob with the highest weight shoud be the only thing on the screen. Is there a way to handle this problem with weights? Or what can i do with the weights?
thanks, robocop
You would adjust the threshold values in each attribute to eliminate those blobs that are not needed. If you include what you have we can make that adjustment and post things back.
Note that you do this for each attribute.
