Barcode 128A Ateeque from India [3 posts] |
Hi, I am New to RR. I have an application in which I want to decode the barcode 128A, I had tried using barcode module but it is not working for the 128A barcode. I checked on forum and with the example for Maxicode, I am able to decode. So I need to know whether it is possible to read the barcode 128A?
Can you include an example of an image that you tested that didn't seem to work? That will help us determine if the current Code128 that we have is not sufficient for your purposes or perhaps why the identification is not working as expected.
Hi, Here is the image for the barcode I am working on.
Yea, there's the problem. The image quality is way to poor for recognition. You will need better focus than that on the bar code. What webcam are you using? Do you have a higher resolution one?
Compare it with the attached:
cindy from United States [2 posts] |
Nana111 from United States [3 posts] |
mariahlewis from United States [1 posts] |
