Take "Floor Finder" just one time and save the value!!
Mohammad Melhem from Israel  [2 posts]
I want To take floor properties using Floor_Finder just one time when the program run, then I want the program to save this value and then do not take any floor properties, so the program continue processing frames depending on the first frame's Floor_Finder.
Any help.Thank you in advance.
Update to the latest version, set the momentum to X number of initial frames that the model should use and then uncheck the continuous checkbox and you'll have what you want.
