Bug in call module
Although the call module seems to work (the final expected result in the main pipeline), I am not able to debug the called module line by line. It seems to be behaving strangely. Please see the test program.
Dawson from Malaysia  [173 posts] 12 year
It seems this problem occurs whenever the call module is invoked within the if statement.
Dawson,
This has been fixed in the latest version. The problem was that the second tab was using an original (unprocessed image) when you were stepping through that tab. We've changed things to ensure that the image created at that point from the call of the main tab is instead shown. That should make debugging a bit easier.
OK great. Thanks.
