Running PowerShell scripts in RR
Does RR support running the .ps1 file type? It would be interesting to enable RR to manipulate the windows file system.
Nope, doesn't support that. You could call a powershell script from the program modules so that's certainly possible.
http://www.roborealm.com/help/Execute_Program.php
Dawson from Malaysia  [173 posts] 13 year
Ok great. Thanks
I tried to load the powershell script from the execute program module as you advised but when i select the file i get the error "only exe files supported". Pls help.
Dawson,
You can't just type in the .ps extension as that doesn't execute. You need to find that powershell exe and send your filename as a parameter to that program.
To test, you can try it in a cmd console. I.e. something like
c:\path\to\powershell.exe c:\temp\my_program
ok great it works now. thanks
