go to line feature Dawson from Malaysia [173 posts] |
I want to process the next blob after determining that the initial selected blob did not meet a specific requirement. RR processes modules in the pipeline in sequence. Is it possible to go back to a specific line number? i cant put all the code into VB as it complicates the programming plus i cant load modules from VB.
I found that it is possible to process the blob without any go to line feature and it was not complicated. Thanks.
ha ha... i think i spoke too soon. i should have tested before i put my last post... sorry. i thought i could get the mean intensity within a masked area for some reason :)
what i am doing is to crop the bounding box area of the mask opening to calculate the mean intensity there. So i still need a go back feature to do another test on another opening if the mean intensity is found to be too high.
Dawson,
I'd use the Color Stats module to calculate that on all blobs (select the individual blobs checkbox) and then use one of the programming modules to skip from one to the next. That's probably the easiest way.
You can investigate
http://www.roborealm.com/forum/index.php?thread_id=4861#
as it has similar requirements to what you are trying to do.
