Blob split feature expansion Dawson from Malaysia [173 posts] |
Hi Steven,
Often times I face the problem where after applying the edge detection filter, the strong edges of the object join with the weak edges of the background. Is it possible to split blobs based on edge strength. Meaning the user can specify the percentage of edge strength at which the blob is separated. This sounds similar to thresholding but it is slightly more involved where you don't just chose a minimum and maximum limit for the entire image. For example, in order to solve my problem I need to split blobs at the point where the intensity of the blob drops below 10%. This filter can be applied from top to bottom or from left to right depending on the option chosen. This would be a very useful feature. Please let me know if you need further clarification. Thanks.
Dawson,
This might be possible ... can you post a source image and then show it processed and indicate which separations you are looking for? We can then better determine what kind of localized thresholding may be needed to get you the desired result.
Hi Steven,
The red line indicates roughly where i want the split to occur.
Hi Steven,
Pls ignore the previous attachment. The wrong file got attached. The red line indicates where i want the split to occur.
Its the right attachment. The file name changes when posted.
Dawson,
I do see the red lines but there isn't anything in the robofile that is actually segmenting the blobs. I've included the autothreshold with a setting that seems to get close to what you want. Can you have a look at that and see what isn't correct? (Note, we have no idea on what we are looking at so we simply can't tell what you really want).
