roborealm error
sazuan from Malaysia  [6 posts]
I have download the marble maze robofile.  But when I open it the error pop up appear.
Any suggestion to solved this?
thanks..
Yes, the file is configured to look for a servo controller hardware board. The message is indicating that this connection could not be made ... I'm assuming you don't have the same board. Just press ok and delete the SSC module which will remove that communication. Naturally, to recreate the entire system you would need something similar to perform the same servo movements.
