screen recording
David Chik from Japan  [31 posts]
Is it possible to record the screen as a movie?
I can use third-party software but is it possible to do it in RoboRealm?
Thank you very much.
from United States  [60 posts] 13 year
If you want to record the entire screen I do not think that is possible. If you want to capture the processing by RR use Write_AVI.
David,
This is partially possible. You can use the Screen_Capture module and the Write_AVI module (as Rud pointed out) to record the screen. Note, however, that the mouse will not be recorded neither will audio.
Instead, have a look at CamStudio which is built for this kind of thing.
