when robofile is reopened... David Chik from Japan [31 posts] |
I saved my work as a robofile. When I reopen it, it loads the wrong files.
I have renamed the original Fiducial folder to Fudicial_Original while I put my own marker patterns in the Fiducial folder. When I reopen the robofile, it loads the original fiducials instead of my files.
Did anyone experience the same problem?
David,
Make sure that there isn't another RR lurking in the background that is still running. When that happens a second instance is started that can have different default info associated with it. So be sure the instance is actually shut down before reloading.
I'm not seeing this issue ... if you can define a sequence that replicates it for you then we can continue checking into this.
