Custom Rotate module crashes for me... Mark [7 posts] |
20 year
I'm having difficulty in rotating an image by a few degrees. The 90, 180, 270 and flips work well, but when I try the custom setting, the program aborts. I tried multiple pictures and resolutions. I tried using an If-Then loop to allow the rotate to only happen once. I thought it might be a case of repeated rotates trying to spin the image like a propeller. No luck.
Any thoughts?
Rotation issues Anonymous |
20 year
Mark,
Can you post the image here that you are trying to rotate. It is most likely the image dimensions that are causing an issue.
Thanks.
Some pictures Mark [7 posts] |
20 year
When the pics I was working on didn't work, I tried the sample remo pic that came with the program
It didn't work, so I cropped it to a square
No luck there so I tried one from another post that you talked about rotating in order to get the lump to the a position on the screen where it could be measured for width.
No luck again.
I've attached a program showing the tools I've used.
Mark
Rotate Fixed Anonymous |
20 year
Mark,
We got that error. Thanks very much!
We've uploaded a new version of RR v1.7.2.30 Please download and try it again.
Also, based on the robo-file that you included you probably do not want to use the if statement as that will cause the image to rotate once, then when a new image is captured it will not be rotated since Rot will be =1. Keep in mind that each loop iteration of the pipeline is started from scratch when a new image is acquired. Thus the rotated image is lost at the end of the pipeline and a new non-rotated one is captured from your webcam (or reloaded from disk) and then the pipeline is started again.
Hope this helps,
