Robo Realm Filter Help Anonymous |
Hi, I'm new to roborealm.
I want to do two things in succession that require different filters, and specifications.
In particular locate a lane, and then choose a direction to go.
Any ideas on how to do this?
Is there a 'reset' option somewhere that I've missed to return the robo vision to normal?
Yes, check out the Marker module ... it will save the current image using a name you provide (in case you need it later) and then can be used to set the image to the Source (original image) for continued processing. Note that you can now recall your saved image in the same way.
Thanks for the quick reply!
