Center of Gravity to Serial Martin from Spain [3 posts] |
I use the "Center of Gravity" module to output the results to the Serial Com-Port.
This works fine only the data wraps to 0 if the result is > 255.
So, is there a way to send a number bigger than 255? With a screen resolution of 640*480 the most right pint on the X axis is a number of aprox 600.
Thanks Martin
Carl from United States [18 posts] |
Martin,
The problem is that a single byte can only
contain values up to 255. In order to send
larger numbers you need to break the number
into a pair of bytes. One means of doing
this is:
B1 = Cbyte(YourNumber And 255)
B2 = Cbyte(Int(YourNumber/256))
The program you're sending this data to will
need to reassemble the original number in a
similar fashion, such as:
YourNumber = B2 * 256 + B1
Cheers,
Carl
Carl.
Lets assume that the variable [COG_X] has the value of 11001000 (400 dec).
I do:
COG_X_lo = COG_X & 255 // result 11001000
COG_X_hi= COG_X/ 256 // result 00000001
Now, the big money thing is: how do I put a function like this into the serial module?
Cheers Martin
Martin,
You simply place the function in a VBscript module
located before the serial module. The VBscript
concatenates the bytes into a string, which is
placed into the global variable space with the
SetVariable function. Within the serial module
send the contents of that variable.
For example:
In the VBscript module:
SerData = B1 & B2
SetVariable "SerData", SerData
In the Serial module utilize SerData as your
send sequence:
[SerData]
Hope this covers it :)
Cheers,
Carl
