Network Tables
Matt from United States  [3 posts]
I am trying to the Network Tables module but having issues on the receiving end. RoboRealm is sending double variables to the robot, running LabVIEW, but is receiving incorrect values. For instance, RR is sending the value 26.0 but the robot receives somewhere in the range of 30.0-38.0, or not update at all.
Is anyone else having an issue with this module?
Matt, 2614
Carl from Your Country  [1447 posts] 14 year
Matt,
If you've not already update RR to the latest version as a lot of NT change were made in the last week. That should at least ensure that RR is doing what it is supposed to.
Then try running the TablesViewer that's part of the NT tools that FRC distributes. Its very useful to see what the values actually are. That will help to tell us if this is a RR issue, LabView issue, etc. You should see the values in the TableViewer correlate to that in RR. If it doesn't that will tell us more.
