Set Array variable
I'm very new to VBScript and coding in general and am picking it up as I go along.
I have a script running to find the MAX_X position of various blobs
    list = GetArrayVariable("MAX_X")
    if isArray(list) then
    for i=0 to ubound(list) step (1)
    write "" & list(i)  & vbCRLF
    edge = list(i)
    next
    End if
SetVariable "edge" &(i) , edge
In the Message box below my script I'm getting the values I need e.g.
Running . . .
236
420
116
This will only display the varialbe of the last MAX_X in the array in this case "edge3 116". I would like RR to assign a variable to all the MAX_X in the array.
I would also like RR to assign a seperate variable to whatever the lowest MAX_X number regardless of the other ones. In this case 116
Perhaps try
lowest = list(0)
    SetVariable "edge" &i , list(i)
    if list(i) < lowest then
      lowest = list(i)
    end if
  next
end if
write "lowest max_x is " & lowest  & vbCRLF
Top Banana. That worked a treat
Thanks for the help
