Multiple clients connected to RoboRealm Server
Paulo G. de Barros from United States  [1 posts]
I am running a remote client that is connecting to my robot. However, I now want to run a client locally in the robot machine to set motor speed in RoboRealm based on bump sensors data I am getting through another API and hardware (Neuron Robotics board). I seem to be able to run either the remote client or the local client individually but not both at the same time. Is it possible for me do run both of these clients at once? I just want to know if this is a problem with my code or if this is a RoboRealm limitation.
Thanks.
Paulo,
I assume you mean connecting to the API server? The API server is configured to only allow one connection (thread) for security reasons. If you increase the number of threads to greater than 1 you should be able to connect using multiple clients.
