WVC200 image not writing to RR...
Jeff from Canada  [8 posts]
Was running RR program with no problem. I had to move my setup to another computer. Upgraded to v2.48.2. Reloaded RR. Now I can't get the image from my WVC200 to write to the RR viewport with Load HTTP. It counts the frames, but nothing displays. The URL used is correct because the image shows up in a browser when the address is pasted into it.
Any suggestions?
Carl from Your Country  [1447 posts] 14 year
Jeff,
Typically that means that it is accessing the camera and loading in frames but is unable to decode the frames. Can you check that the camera is still sending MJPEG images? If anything else is coming across that it doesn't understand you'd see this behavior.
