RoboRealm Closing After Opening Options Menu
When I open the options menu, and click ok at the bottom of the window then entire RoboRealm program closes.  I do not know if this is supposed to happen or not, and if not what could be a possible solution?
Sounds like your trial copy is about to expire or you had a bad install. You can use the contact form to send us your email address and we can check your account and send you a .zip install instead which may work differently on your system.
