RoboRealm and wifi Stanley Venable from United States [4 posts] |
I'm using a Trossen RoboTurret Vision Tracking set up. Works fine, but I would like to make it wireless. Is this possible. Is there a way to send everything from the usb wirelessly?
I thought of trying some of the robots that are sold as wireless but those that are already set up for roborealm are mostly no longer being sold, like Wow we and the parallax bo bot, even spykee doesn't seem to be available anymore.
Not sure which version of the Turret you are using ... but if it is the most recent then you could look at any Arduino wireless serial connection like XBee to make the PC to Arduino connection wireless.
There are also USB to ethernet bridges that may also work for this. (As in the USB connection looks normal to a PC but it is over wireless 802.11). Products in this space are mainly used for printers.
Or you could also look at boards like wifly
https://www.sparkfun.com/products/9954
http://www.diybin.com/products/DFRobot-WIFI-Shield-For-Arduino-802.11-B-and-G.html
or you might be able to purchase an Arduino with a wifi connection.
Thanks very much for quick reply. I'll be looking at all of these. My basic problem is getting the video back to RoboRealm. I want to be able use RoboRealm while I move my desktop turret around on my roving robot. That actually requires both the arduino and the camera to be wireless. I see that someother robots are already set up for that in RoboRealm. I'm pretty much at a loss with how to do it from scratch. Well I'll checkout your sugestions and see what I can come up with.
Thanks verymuch for the help.
stan.
Alan Coggins from Australia [32 posts] |
Hi Stan,
Another option you might want to consider is to use a compact PC as a sort of robot server. You can run RR on this and it will handle the webcam - if you add a usb wireless adapter you can do everything from your PC via remote desktop. This is the one I used:
http://robosavvy.com/store/product_info.php/manufacturers_id/45/products_id/1704
Mind you, I've gone to a lot of trouble and expense and I've only just managed to make something that has the same functions as my old Spykee robot!
Hi Alan,
I have been looking at this solution ever since you posted. It's exactly what I want to accomplish but I'm not sure I can afford It. Besides the pc there would be upgrade cost for handling all the weight. I'm wondering if the Rasberry pi might be workable? It's running on linux, that's not good. Unfortunately I don't know enough about hardware to know if it could send usb info that can be read by windows. If you read this, let me know what you think. Sheesh! What kind of motors do you need to drag around a lap top.
Stan.
