This Thread
 New Post   Forum Index
Identifying X and Y COG serial data in RR.
Wilfredo Molina from United States  [13 posts]
9 months
Is there a way to identify each serial X and Y COG coordinate in Roborealm?
I need to tell a device that receives COG_X and COG_Y where each one begins or ends?  Thank you
Wilfredo Molina from United States  [13 posts] 9 months
What about a kind of parser like <cr>[COG_X]<lf>[COG_Y]?
Anonymous 9 months
Yes, that would work. Alternatively
[COG_X], [COG_Y]<cr><lf>
is more commonly used (comma separated with newline EOL).
I am having problems reading the COG_X and COG_Y coordinates. What I really need is to make a way in C++ to read them as separate variables. For example, I need to save COG_X like int axis_x = COG_X and COG_Y like int axis_y = COG_Y. Is that possible using a C or a VB script? So far, all my attempts to do it have failed. Any help will be gold for me. Thanks.
Anonymous 9 months
Wilfredo,
When you say C++ I assume you mean from your own application?
Have you seen the API?
The first link is a download of examples of how to use it to do many things including get a variable value. There are C++ examples in that download.
Thanks for your answer STeven. I forgot about the coordinates manipulation in Roborealm and decided to do the programing in an Arduino compatible board. I had to use flags like .,; . Here a video of my project using Roborealm together with Osepp (Arduino compatible),Bipom and XBee technologies.
http://youtu.be/n9H5PwDrJhQ
© 2005 - 2013 RoboRealm. All Rights Reserved. | Contact | Glossary | Privacy | Disclaimer | Link to Us | Resources | Site Map
