vb script pratim from India [1 posts] |
i am having problem with the vb script program. i want to make a simple ball following robot using vision processing in roborealm.. i hav added the RGB filters, COG. but i am unable to run my vb script program..
here is the program that i have written..
xaxis=Getvariable("COG_X")
objsize=GetVariable("COG_BOX_SIZE")
if (objsize>10) then
if (xaxis>160) then
SetVariable "pin2",0
SetVariable "pin5",1
Else if(x axis<160) then
Set Variable "pin2",1
Set Variable "pin5",0
end if
please find out what is wrong with the program..
please help me out at the earliest...
You had several issues with your script. Missing 'end if', 'Set Variable' is one word. Perhaps you would prefer the CScript module? Your style seems more C like. Regardless, see if this version helps
if objsize>10 then
if xaxis>160 then
Elseif axis<160 then
SetVariable "pin2",1
SetVariable "pin5",0
end if
end if
