Lynxmotion SSC-32
Jape from United States  [16 posts]
Message has been removed based on user's request.
Jape,
1. What you say "have to have it active" what do you mean by active? Meaning when you disable that module or press the stop button things no longer work?
If you do not have an active camera you can try to change the Options Dialog->Other tab->Min Processing FPS to force the system to continiously iterate through the pipeline.
What version of RR are you using?
2. If you read the comments on
http://www.hobbypartz.com/12exiseb1.html
it seems that others are having problem with continuous rotation. There is a suggestion on removing a part to make it continuous ... may want to try that.
Jape from United States  [16 posts] 14 year
Jape,
1. Yes, that's the way it is supposed to work. Once the module is removed or disabled in the pipeline it will no longer function. That's the intended use. I think maybe I'm still not fully understanding your issue.
Is the camera button pressed and are you seeing video from the camera?
