Underwater ROV serial communication and other questions Andrew PArsons from Canada [2 posts] |
Hello all,
First I would like to say thanks to the community for helping me get this far in my project. In truth this is my first attempt at programming and using a micro controller to do my bidding. In the past I did everything using servos and switches. Although I have ran through the education courses with Parallax and have done all the projects.
I have tasked myself with making an Underwater ROV. I plan to use one are two Basic Stamp 2sx. One stamp (below sea-level) will read sensors and control 6 thrusters by using the Propeller Servo Controller to PWM to six ESC. I will also be using the Prop Servo Controller to manipulate an underwater arm. All the motors are brushless (Including underwater servos) and have been tested underwater. Each ESC will be powered from a 3s poly 5000mah battery that will be housed in Otter Boxes along with all the components. As for video I have not quite figured that out but it will most likely be a netcam with pan and tilt that I power below and break the lines out to the surface. If anyone knows how many pairs from the cat 6 a netcam will need please let me know? As for communication from surface to the ROV I plan to use RS-485 Communication; actually this is one of my questions. Above I mentioned using 1 or 2 Basic Stamp 2 SX, does it make more sense to use a microcontroller on the surface with pots to control the ESC using RS-485 Signal? Or does it make more sense to use SparkFun BOB-09822 for communication and have RoboRealm to control the ESC and display sensor reading?
I am leaning toward using SparkFun BOB-09822 since I like the Idea of the increased resolution for the ESC compared to pots. So, If I do decided to go with BOB-09822 (already have 2 of them) how would I connect them in order to serin and out to the BASIC STAMP Below and use RoboRealm?
I know I have asked a significant amount of questions, and I do not expect one person to know them all. Also, if you have any suggestions on my project please post them.
Andrew
[29 posts] |
Doyle,
Thank you very much for your help. More over I would like to further thank you for your help on the video side of things.
You are correct, my ESC are having a hard time running at low speeds not to mention high loads, the motor seems jolt at times. These Jolts, i fear, will be quite the issue when below 200 feet.
Currently my ESC and motors are not sensored, would thier be any point in going to a sensored type situation?
Again, Thank you.
Andrew
[29 posts] |
SERGIO DA CONCEIÇÃO from Brazil [1 posts] |
