use one of two cropped windows
John Wood from United Kingdom  [67 posts]
hi Steven,
Is there a way to choose a cropped window from a choice of two...
I have the Pic send  a variable "low" on the serial connection and would like it to use cropped window 1 . if variable "high" then use cropped window 2.
How best to extrapolate this and control the pipeline.
Simple terms please....
I am now at the point of completion and I have a work round for the above problem though far from flawless...the above if possible would cure the last hurdle.
Cheers
john
John Wood from United Kingdom  [67 posts] 13 year
Should mention, the variables could be string or numeric which ever is easiest it is is even possible,
I could send the high with infra red link but not too sure how or where to go using this approach.
John
John,
Assuming that the serial module is setting a variable you can use two if_statement modules to achieve this. See attached.
