Barcode problem
I can't move the green line location by mouse in  Barcode Reader module .Why?
The green line is generated by the module and just shows where it found a barcode. The barcode routines will check the entire image at any orientation (unless specified not to) in order to find the barcode. So telling it where to find the barcode is not needed.
I.e. you cannot change it since its not for you to edit. It is the result display.
Does that help?
