arduino ethernet shield abdelsalam from Egypt [4 posts] |
hi steven , i wanna to know how can i use roborealm with arduino ethernet shield to control robot through wifi connection .
abdelsalam,
It is similar to controlling it through serial connection but you'll have to decide on how to modify a sketch to work with the ethernet card and how that communicates to the PC. The Arduino module uses a sketch that you can download and modify and then use the Socket module to send communication to the arduino. Or you can also take the MCU sketch and do the same ... or just write your own sketch and use the Socket module to send the required bytes to the arduino.
