compairing variables Fraser from United Kingdom [5 posts] |
How would i compair the the COLOR_SAMPLE_NEAREST Variable from the sample color function to a preset variable in an if command?
Fraser,
It will be an array of strings. Use
COLOR_SAMPLE_NEAREST:0
in the If Statement module to request the first (0) element of that array.
You will need to download the latest RR for this to work as we updated the If statement to accept this notation (standard in many other modules).
See attached for example.
thanks for the examl thats helps a lot on a side note . under the currnt trial version roborealm crashes every time i try to use the serial or arduino modules. running windows 7 32 bit
any ideas?
Fraser,
Yes, the changes we made to fix the variable comparison caused a serial creation issue. The fix to that was just uploaded. Can you download again and give those modules a try?
