Serial module
Roygul from Australia  [3 posts]
The serial module wont remember by serial port. Its the only module loaded. I can select the port from the drop down. remember default is ticked, I can see data flowing, variables get set, I click ok. when I go to edit the module the serverial port field is blank.
When loading a program (Just a one line test with the serial module) port is always blank.
I have an arduino freetronics eleven and two FTDI serial ports connected to the machine. Serial Drivers are up to date. I removed all usb serial except for one . Module still cant remember setting.
What am I doing wrong :)
Roborealm version 2.44.9
Roygul from Australia  [3 posts] 13 year
Digging a little further it seems the wrking robo file that is being saved contains the following
<head><version>2.44.9</version></head>
<Serial>
  <remember_as_default>TRUE</remember_as_default>
  <flow_control_out_x>FALSE</flow_control_out_x>
  <enable_send_sequence>TRUE</enable_send_sequence>
  <port>COM1</port>
  <data_bits>7</data_bits>
  <baud>8</baud>
  <flow_control_in_x>FALSE</flow_control_in_x>
  <read_rate_index>-1</read_rate_index>
  <flow_control_dsr>FALSE</flow_control_dsr>
  <flow_control_cts>FALSE</flow_control_cts>
  <send_only_on_change>TRUE</send_only_on_change>
  <send_frequency_index>-1</send_frequency_index>
</Serial>
Note I have changed the com port to 6 on this machine data bits are 8 not 7 etc etc. Is this a bug ?
I dont think its a permissions problem as it is writing the file.
Cheers
Just further infor mation to this. seems the wooring file gets changed from com 6 to com1 when I start roborealm it gets a blacnk serial port assigned instead of 6 . and on exit changes the one in the working file to 1.
Cheers
Roygul,
This should be fixed in 2.44.10.
Thanks for the note!
