Web Server - Ip Addresses Juan Cabrer from United States [11 posts] |
I'm wondering if it is possible to display information about the connections to the web server. IP Address, Duration, Last Command, Ping Time?
John,
Do you need that information within variables to be used/saved elsewhere or is it sufficient to have that in the webserver configuration message box?
Note that the last command would be more related to what variables were sent into the system as the "last command" would depend on what the system is configured to use in terms of variables.
I doubt we would put Ping Time in as that would require much lower level network control. If there are specific things that you are interested in knowing from that (perhaps country location,etc.) let us know and we'll see if there is a way to calculate that.
