Vision based commands Dave F from United States [3 posts] |
Is there a way to use the shape matching feature to command a robot (in my case a Vex Protobot) to do something based on the input? For instance, if I wanted the robot to, say, turn 90 degrees counterclockwise when it sees a square (an image that would already be known to the robot), could I, and how could I, do that? I'm new to the program, and for all I know the answer is blatantly obvious, but I would greatly appreciate any help.
EDV [328 posts] |
Dave,
As EDV points out using Fiducials or Glyphs is what you probably want to use. You can also have a look at the Fiducial module
http://www.roborealm.com/help/Fiducial.php
and react based on the name of the image being recognized. The advantages of using fiducials is that they can be recognized at many orientations and different angles which is normally the case if someone is showing the shape/fiducial and would not do so in a perfectly perpendicular angle.
Thanks. That's exactly what I need- the one thing I need to know is how to get the input from the webcam into the microcontroller ( I plan on using a wireless webcam) so it can be compared to the fiducial database.
Dave,
Just a clarification .. the fiducial database would be on a PC instead of the MCU ... which most likely may not have enough room to keep that on it anyhow. Typically the sequence is Camera -> PC -> MCU with the PC doing the vision processing and sending a final move command to the MCU over something like serial.
If you really want to remove the PC from the mix you'd be looking at something like a BeagleBone board which is capable of doing some vision processing but you'd then be programming that using a much lower level system than RR. RR does not yet run on the BeagleBone board.
Naturally there are many other boards then the one mentioned above that can do a similar task ... that one just happened to be in mind.
