Converting to C codes Anonymous |
20 year
Hi everyone,
Just to ask simple question, does RoboRealm has feature that can create C code for each image processing function?
Thanks in advance :)
C Code Anonymous |
20 year
Looky,
To be blunt ... no.
However, we do provide a vast amount of interface capability to have other applications use RoboRealm by either a documented API or Extension interface. You can also use our search interface to search many other open source vision programs that do have the source code available or are packed as linkable libraries. For starters for C/C++ have a look at OpenCV and FILTERS.
Good luck on your hunt!
Ariel Estrada from Chile [1 posts] |
Ariel,
The assumption is that you know how to use Python and want to use that language to communicate to RoboRealm. Based on your question above it sounds like you are not familiar with Python.
What is your initial thought that lead you down this path? I.e. what do you want to do?
