VBScript Blob Count and Display Text
I have a VBScript Problem.
I'm developing a counting program, where it will display "PASS" if the number of blobs is equal to 8
How do I display a text if my variable results is equal to 8?
I've written the VBScript codes.. There seems to be a problem because it always displays "FAILED"
blobs = GetVariable("TAB1_THICKEST")
      if blobs = 8 then
  SetVariable "RESULT", "PASS"
else
  SetVariable "RESULT", "FAILED"
end if
Thanks in advance !
It will depend on what previous filters you have. It seems like you may be using the Blob Filter module before this script? Perhaps if you include a sample image and your robofile we can better help.
You can also add the Watch module to see what variables exist at that point in the pipeline. Not sure where the TAB1_THICKEST variable is being created.
