Multiple if Statement Ash from Malaysia [2 posts] |
hi guys...im having problems using multiple if statement..
in my program, there are 3 blobs present and with circular area variable i have 3 different values..0.6,.03 and 0.5
i would like to use if statement --if circular area>0.6 display text ( present) and --if circular area <0.6 display text (not present)
the problem is that when i change picture that have 2 blobs with values <0.6..
the program still shows (cap present) no matter what i tried.
Ash,
Its probably easier to use a bit of code (like VB) to do this checking. Assuming this is after a blob Filter module. Do NOT forget to select the "create array variable" in the Circular Area GUI (not the Create BLOBS array variable as that is different)
capPresent = false
blobs = GetArrayVariable("CIRCULAR_AREA")
if isArray(blobs) then
if ubound(blobs)>=0 then
for i = 0 to ubound(blobs)
if blobs(i) >= 0.6 then
capPresent = true
end if
next
end if
end if
if capPresent then
SetVariable "RESULT", "Cap Present"
else
SetVariable "RESULT", ""
end if
thank u for the reply..i will test it and see how it goes..thanks!
