Training through API call Anonymous |
Is there a way to train the object recognition module through an API call? It seems that I have to click on "Train" at least once after loading the .robo file before the module starts recognizing objects. I would like to be able to do all this through an API call.
Thanks.
James Dickinson from Australia [49 posts] |
at the top of your robo file add a vbs module with the code of
PushButton "Object_Recognition", 0, "Train"
to have it only go once you could do
if VariableExists("STARTUP") = false then
PushButton "Object_recognition", 0, "Train"
SetVariable "STARTUP", 1
end
James is correct ... that will do the trick but we also noticed that there was a small problem on startup that prevented the template file from being loaded and run. This has been fixed in 2.42.7. Can you download and try again?
Also, there is a "monitor folder" checkbox in the Training interface that if selected will check the folder and retrain when a new file is placed into that folder. (In case this is easier for you).
Regardless, you should not need to train the module when you startup RR if you have already trained it.
Thanks for the note!
