<response>ok</response>
I run "rr.execute "<head><version>1.50</version></head><RGB_Filter><min_value>40</min_value><channel>3</channel></RGB_Filter>",How can I get  <response>ok</response> after running over?Please give me an examples.
I'm not sure I understand your question. If you use the above command you would get an ok meaning that the script was taken into RR and started execution. If you are looking for the resulting image you'd need to use the rr.getImage function. Keep in mind that any robofile xml sent to RR is executing many times a second if an active camera is running. So by calling getImage many times you would get different results depending on what the camera is seeing.
Or perhaps I'm not understanding your questions correctly?
