getImage C# Berk from Turkey [10 posts] |
Hi, im trying to get the current camera view from RR on show it on my application by
Dimension d = rr.getDimension();
byte[] image = new byte[d.width * d.height];
rr.setCamera("on");
rr.run("on");
d = rr.getImage("source",image, d.width * d.height);
but it just returns null and i dont know why. Any idea ? Thanks for the help :)
Berk,
Try stepping into that getImage function with the debugger and see where it fails.
I assume you have all the rr.connect also above this code?
Ensure that RR is running and has the API activated (off by default).
Well, in debugging mode, i solved the problem. Thank you :)
