to get the video feed from RR onto a VB program Anonymous |
The main idea is to get the video feed from RR onto a VB program and RR is faceless .
Marc [7 posts] |
I think you can use Virtual camera for this.
Unstall de virtual camera driver from Roborealm and connect you VB program with this virtual camara driver.
u can see that the vc driver shows the RR result screen.
Marc
You can also use the API to do this. Have you had a look at the COM object for the API? It has a GetImage function which will return an image that is currently in RR. There is a C++ example on how to get an image and display it in your own application in the API.zip download. Using the API will probably be the easiest way to do this.
