avm CJ from Australia [21 posts] |
hi there its cj i just wanted to ask i am trying to use avm with my nxt and i currently have got my robots head on a tunable base however i make it learn an object and i make motor a variable equal turret balance but it continuesoly turns left it wont stop or turn right or anything do i need a vb script if so could you please point me in the right direction as i have never used these could you please make one for me if necessary so i can study it thanks in advances
EDV [328 posts] |
You should use servo for camera turning and use variable NV_TURRET_BALANCE in this case. But if you use just simple motor instead servo then you could use variables NV_TURRET_LEFT and NV_TURRET_RIGHT and you would use VBScript program like this:
nv_L_Motor = GetVariable("NV_L_MOTOR")
nv_R_Motor = GetVariable("NV_R_MOTOR")
nv_Turret_Left = GetVariable("NV_TURRET_LEFT")
nv_Turret_Right = GetVariable("NV_TURRET_RIGHT")
nxt_L_Motor = round(128 + (nv_L_Motor/100.0)*127)
nxt_R_Motor = round(128 + (nv_R_Motor/100.0)*127)
nxt_Turret_Motor = 128
if nv_Turret_Left <> 0 then nxt_Turret_Motor = 64
if nv_Turret_Right <> 0 then nxt_Turret_Motor = 192
SetVariable "NXT_L_MOTOR", nxt_L_Motor
SetVariable "NXT_R_MOTOR", nxt_R_Motor
SetVariable "NXT_TURRET_MOTOR", nxt_Turret_Motor
For more detail see attached program file below:
Thanks so much I finally got it working just had to make a few number changes as the head is moved by a worm gear thanks again :)
EDV [328 posts] |
But servo would be better solution for camera turning because it participates in initial localization of "Marker mode" and "Navigation by map" modes for camera getting of state "look forwards".
But it's a nxt motor and under servos I don't see nxt so I have to use the method above right?
EDV [328 posts] |
In dialog window of RoboRealm "Lego NXT" module there is "Servos" page. So, if you have lot of servos amounting to your NXT then it would be better to use it with camera turning.
