Bone Fracture Detection Procedure-Machine Learning tasneem ghnaimat from Jordan [4 posts] |
Hi All,,
I am required to prepare a research in detecting fracture in long bones in x-ray images,,
1- is it required to convert the image into binary image? or I can process it in gray scale?
2- what are steps used in thi procedure?
3- Can I statistical models in thi procedure?
Thank u very much,,,
Tasneem ///ghnaimat
Tasneem,
You should convert it into binary if you need to perform blob analysis i.e. analysis that would include statistics about the shape, area, etc of the object. This is normally the case in most projects that require stats but not always.
If you are using RR in your project and cannot post images or explain in detail what you need you are welcome to use our contact form to send us more specific information. Note, however, we do not respond to requests such as "I need source code for X".
Please also have example images of what you are trying to process ready to send too.
