VBScript to Keyboard Send Ben from United States [4 posts] |
I am trying to make a usb missile launcher follow a red blob and then shoot it when it centers on it. (see attached) I am using the Keyboard_Send module to send a left or a right keyboard arrow to the missile launcher program.
The only part that does not work is reassigning a different value to the "key_ to_send" variable each time I move the blob. For instance when I move the blob to the left and test <=100, "key_to_send" is still shows up as equal to {RIGHT} (under the modified Variable table in VBScript module) instead of {LEFT}. So the missile launcher continues to turn right.
Let me know if you have any advice.
Here is the VBScript I am using( I have attached the .robo file I am using):
cogx = GetVariable("COG_X")
leftThreshold = 100
rightThreshold = 200
SetVariable "test", cogx
if test <= leftThreshold then
SetVariable "key_to_send", "{LEFT}"
else
if test >= rightThreshold then
SetVariable "key_to_send", "{RIGHT}"
else
SetVariable "key_to_send", ""
end if
end if
leftThreshold = 100
else
else
end if
end if
I copied the code twice above, it should just be:
leftThreshold = 100
else
else
end if
end if
