unrecognized image type Anonymous |
I am having trouble with the Load_Image module. When I select the "Read Images in Folder" option, I get the error: "Unrecognized image type! Please select a jpg, png, gif, etc. image file." I have verified that the images are good, and that there is nothing else in the folder. I can load the images one by one just fine. I even tried the Write_Images module to create jpgs.
I would be grateful for help with this.
There was a problem when you specified a full filename path and selected the "Read Images in Folder". This has been corrected in the latest version. You can either download that version or just remove the filename part. I.e. if you specified
just use
c:\some\path\to\read\
and that should work. Again, you can also download the most current which will now accept the filename too.
Just to be complete, in the current version when the full path is specified it will only look for images with the same extension as what was specified. I.e.
in the above example. So if you do need to have non-image files in the folder that specification can help to remove those issues.
It works great! Thank you so much.
