x10 firecracker
Danh from United States  [79 posts]
Steven,
Can you add support for the x10 firecracker?
http://www.x10.com/products/firecracker_x10_cm17a_br1ab.htm
I used this with a VB program on my bot to control room lights. It does require toggling the handshaking lines of a true com port (don't think usb to serial converters work). however, most bots using a mini-itx board still have true comports.
thx
Danh
Nice! Should be a good cool addition ... the order is on its way. Look out for that new module in the next 2 weeks once we get the hardware. Do you have any links to the VB code that you used? Would help us get a head start.
Danh from United States  [79 posts] 14 year
Steven,
I had downloaded some VB code from the web to control the firecracker for my iRobot Create contest robot. I don't remember the exact source but here are some links after googling:
http://www.ubasics.com/adam/electronics/cm17.shtml
http://www.rentron.com/firecracker.htm
I'm working on a larger version of my home robot that will have arms capable of interacting with home appliances. More to come by mid year.
thanks,
Danh
