Is it a bug in API
Kshitij Burman from India  [10 posts]
With the help RR API i can communicate with RR, but only for once.
For i.e(In VB.NET)::::
    When use         Private Sub Button1_Click................
                                          label.text = rr.GetVariable("COG_X")
    then on first click i can get the value but in next click whole application hangs.
I have uploaded the source code of my app.
please get me out of this problem
RRAPI.zip
Not a bug but a misunderstanding. You should only call
rr.Connect("localhost")
ONCE per session. If you want to use it like you have it in your program you will have to use a
rr.Close as in
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        If Not rr.Connect("localhost") Then
            MsgBox("OK", MsgBoxStyle.OkOnly, "Could not connect to RoboRealm Server")
        Else
            Label1.Text = rr.GetVariable("COG_X")
            Label2.Text = rr.GetVariable("COG_Y")
            rr.Close()
        End If
    End Sub
if you want to use the connect each time. Note this is not recommended for high performance but should be plenty fast to service user clicks.
